information on mini plc's needed
medelic
May 2008
zagreb
I'm searching for a mini/ micro plc that operates on 110/220 VDC with (at least) 2 analog inputs and outputs. So far I've came up with nothing. Can anyone give some usefull informations on possibilities of finding such thing....?
OK, so this isn't the answer you were looking for but I would go to someone like this, add a DC/DC converter into the circuit and then have the choice of any PLC with a 24V d.c. input. They don't do 110/220DC input as standard but will make whatever you need.
Bryan
Not sure what you mean by 110/220 VDC
OMRON CP1H-XA40D...-A is AC powered and has 4 analog inputs and 2 outputs on the main unit.
actually I think I might have found it so if anyone should ask it's idec smart relay, I've already thought about using converter but this has 0-240 VDC range of operation ( 110 VDC or 220 VDC is standard control voltage in central europe, well germany and ex-yougoslavia, for sure )
http://www.idec.com/usen/products/Catalogs/SmartRelay/SmartRelay.html
In case you have some OTHER option please notify me.
THANK YOU for your help and asistance
Rockwell in their wisdom have made a mess of the Panelview Plus 7 operator interface terminals with all the different series hardware revisions...
332
Hello Everyone, I am setting up an Information message in FactoryTalkView ME. I'm just using the default information display. I want to make it...
852
I have some programs that i received from 1 of our programmers whos installing a new machine in our plant. He added them to a external hard drive...
1,359
I have a client with a program he's trying to load into an older FlexLogix controller (1794-L34/B). He has the program, but I'm thinking the...
560
I often need to search for answers. What really p!$$e$ me off are long web pages and videos where I must waste a lot of time getting the info...
19
5,364
