Is it not a mistake? Programming technique.
EStufC
May 2019
Kikuara
69
hello,
Currently I'm playing with a module which has a command for getting its status. And I'm a bit puzzled by this picture which is provided by manufacturer. See attachment.
The question is, as per word mapping I should assign zeros only to bits 12,13,14.
However, what confuses me that if it is workable way "assignment zeros amid other not touched bits", I mean that anyway they (not touched) also have "zeros" by default.
In my opinion the module should not recognize a command. Actually what exactly we have right now.
Please any insigts on this matter?
Hi Buddy
I'm a little confused on what we are working with specifically, maybe you can shed some light for the rest of us forum members.
But if I am not mistaken, your asking how is it possible for a write command to only write to certain bits of a word. If your familiar with any allen bradley (simplest example) programming, that we often only write & read 'sampleword.bitnumber".
When you want to read the status have a bit set.
Then, when that bit is on have 3 OTU (unlatch) outputs that turn off those 3 bits.
That will turn them off without effecting any of the other bits in the word.
If they made their own odds are you will need to contact them, give us a screenshot of the software and maybe it will just be private labeled
Frankly speaking, I can't get anything useful from manufacturer, due to unsufficient professionalism of those people who is in charge of support. I have strong feelings that I'm always speaking with moonlighting students which were applied by the company to perform some support. In other words we haven't any access to someone from developing of this company. Nowadays almost every company has similar organization, though.
S7-300 series, it can be LAD, FBD or SCL.
In the S7 world, if the command telegram to the device is at, say QW10, then you could turn off bits Q11.4, Q11.5, and Q11.6. In LAD, that could look something like this:
"Get Status" Q11.4
-----||------------(R)
| Q11.5
|-------(R)
| Q11.6
|-------(R)
Can you tell us more about how you exchange data with the device ?
If the device in question is on Profibus, it is possible that it uses little-endian, whereas the S7 PLC uses big-endian. Maybe you have to swap bytes.
As you wrote in your 1st post it confuses you that you have to turn bits off to have diagnostics data. Yes, that sounds very odd.
This sounds familiar, is the card a 6ES7090-0XX84-0FF5
if it is it's a coms card to connect a simovert drive
Well spotted (if you are right about that).
If it is indeed a Siemens "PROFIBUS CBP2" for Simovert, then you definitely do not have to swap bytes.
There are a couple of FAQs, manuals and sample projects on Siemens support for that adapter.
Amid usage DPRD_DAT, MOVE_BLK and simple MOVE blocks to command this module, this simple LAD logic looks a bit rustic. o_OI've even tried masking words in a bid to achive some effect, but to no avail. Anyway I'll try that method.
As concerned byte representation it's being used Big Indian format, since I'm using the same module registers for different kind of commands and have no problems. The only one function is still defying, -Status.
if it was Siemens device, probably I would have decent support. :)
I am looking at analysing a sting using an FB in SCL. I have looked at these...
1,565
Hi, I am having an issue downloading to my HMI from my PC. It has been working fine for the last 2 weeks but it must have the Monday morning...
14,651
Hi guys, I am facing a problem on barcode printing mistake. There is one conveyor,two product is going to robot to pick up.my questions...
27
4,791
I am currently working with a PLC having a power supply unit that accepts dual input voltage (the one that tells "short 110V, open 200V"). I must...
22
4,146
RSLogix Emulate 500: FYI This 1 line, 2 instruction, ladder code causes a controller fault in the emulator, but always runs perfectly on a...
2,410
