Kepware
mrtweaver
May 2007
Bloomsburg
329
I was wondering if any of you Kepware Gurus could assist in the following question. In the Kepserver program you have a pane on the left side of screen that displays configured channels/devices. What I am trying to figure out is how to change that display to show the proper numerical sequence. Currently it looks something like:
1, 2, 3, 31, 32, 33, 34, 4, 5, 52, 53, 54, 55, 6, 7, etc...
I would like to have it appear as a proper sequence:
1, 2, 3, 4, 5, 6, 7, 8, 9, 31, 32, 33, 34, 52, 53, 54, etc..
SO is there a way to accomplish this?
Thanks and have a great day.
You have to give them alpha-numeric names that can be sequenced, i.e. D01, D02, D31, D43, etc. Then they will sort correctly.
as with a lot of programs, they list them as you have said i.e.
d01,d02 ... d022 the best way is to give them alpha only descriptions or limit the numerics to 0-9 i.e. digitalregs01-09
analogregs01-09 etc.
What usually 'solves' this problem is making sure each name has the same amount of digits. ie 001, 002, 025, 068, 100, 248, .... but then again when your software discards the extra 0's, then it's best to use the above mentioned solutions.....
I have a strange Kepware issue I have been dealing with for a few weeks. I have Kepware setup with the Omron NJ Ethernet driver and reading in...
107
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
172
Im trying to get data from AB guardlogix controller using Kepware in a remote location but it seems that version 6 can only support contrologix...
451
Hi, Have anyone came across issue with Kepware or Linkmaster not returning correct values (Unknown Quality) for some tags From OPC DA Client...
692
I’m attempting to configure KEPWare to poll a Modbus device via Modbus TCP/IP. However, everything I’ve tried results in an error being reported...
427
