Kinetix 5700 Overcurrent
Wabbit87
Sep 2020
Arkansas
Had a weird issue with a fairly new installation of a Kinetix 5700 servo drive. We were getting an overcurrent fault on the system. Normal % current pull is around 100%, however we were getting around 340% current. Checked all mechanical, inspecting for any binds or tight spots, lubricated all sliding parts and joints. Was still getting the same issue of high current. Eventually tried power-cycling the equipment and the issue cleared up.
Just found that kind of odd that a servo repeated overcurrent faults would occur and then get cleared up by power cycling the equipment. Hope this helps if getting the same issue.
ADC calibration probably initialized incorrectly. That would easily introduce a current offset that won't go away until the system is restarted.
Kindly, we have the following faults with a Kinetix 5700 servodrive. We checked the encoder cable, but found nothing damaged. What could be...
293
Hello everyone: I am looking at the possibility of migrating Kinetix 6000 to Kinetix 5700(460V 3 phase). Reviewing the drive catalog, I have the...
1,154
Everyone, I am having an issue with our current program and need advice. Our current setup has 4 servos running on a pusher chain conveyor. The...
482
First time poster and somewhat new to PLC programming. I own a brewery, have a programming background, and one of the machines on my canning line...
978
Hi When using Studio 5000 & Kinetix 5700 drives would it be possible to change drive setup from the PLC code. the senario is that i have a servo...
488
