Let’s practice brain!
PB1 NO direct to L1 and thru PB2 NC to horn
PB2 NO direct to L2 and thru PB3 NC to horm
PB3 NO direct to L3 and thru PB1 NC to horn.
What I did was transpose
PB1 NO to horn and thru PB2 NC to L1
PB2 NO to horn and thru PB3 NC to L2
PB3 NO to horn and thru PB1 NC to L3
Tried to making a drawing but couldnt. Mute point now. I knew the common denominator was the horn and the lights had to be wired so they would not interconnect.
That Really ****es my off. I used to be good at that stuff, but after years out of school, I suck. If my Prof. allowed my to switch neutrals like that, I think I would get an F-. Soooo you can switch neutrals? Not in my country, but for that?
John
that aint right either..oh well
This my country is better than another **** is getting old...I dont know of a place that doesnt break neutrals. Look at Overloads.
It doesn't look like that one will work either. Once again you will get 2 lights (and buzzer) with 1 PB press.
Here's Ron's #2:
[attachment]
rsdoran said:
Mute point now.
I thought you really had the solution. If I'd known you did not know how to solve it, I wouldn't have questioned you directly.
Sorry, Ron... :oops:
Well said Rsdoran. We all love our own Countries, but there is a point. Who (whom) invented the PLC? AMD? Aliens? Or that guy in the commercial, picking herbs with his Grandmother. Maybe he got a dose of the 'good stuff' from the crop circles?
Johnny
Fun with MS Paint...
I didn't have time to wire-tie everything neatly, but I think this should work... ;)
[attachment]
I realize the 'rules' state "Do not add any other elements", but I added a fuse 'just in case'... :D
beerchug
-Eric
My 2 cents
Take note on the Light Positions.
Anyway PB1 Lights up L1, PB2 Lights up L2 and PB3 lights up L3 beerchug
Sorry, never know .bmp will attach as file. See the next post
I like Chavaks solution best.
Here I attached it so you don't have to download the Bitmap.
Oh never mind!
He fixed it.
Re: My 2 cents
This one will also let 2 lights per PB press. When PB1 is pressed LT1 and LT2 will light. This is the same thing as Ron's first attempt above...
Hello everyone! So basically I have this PF 525 that no matter what I do won’t let me speed down. It always shows 66.66 Hz and the parameters to...
1,194
35 years ago - 167 Souls were lost on Pipe Alpha (Oil Platform in the North Sea) all due to a failed management system See more information here...
806
I have begun using 480VAC power supplies in my panels to keep heat from a transformer out of the panel. This works great if the panel is mounted...
17
4,147
I am deciding on components for a bayed modular enclosure containing multiple VFDs (480V/350A/321Hp each) for a dynamometer. I am concerned given...
1,717
Hi, I am having trouble with the comms within FT view SE v11 (premanent license). I created an HMI program a while back which was working just...
930
