Locating Outputs in Siemens Step7
when I go back to post #14 I get a
"Should the reference data be updated or regenerated or both?"
Also Ive went thru 20 FB and they are all with the # in front of the Instruction/s.
Don't give up on me now , your doing great!!
Regenerated.
When this has been done it should finish and open up the x-ref window. If asked then select "Cross references.
After about 30 FB's, I have located my Output in FB217. This still doesnt resolve the issue I have with PROMPTLY locating I/O.
The Hunt Continues
The Hunt Continues
As stated before you are confusing PLC Inputs and Outputs with the FB IN and OUT parameters.
Have sent you a pm
Make that 2 Beers. I now can click on any FB and
Options>reference data>cross reference and Voila!! I/O Addressing.
Hail the moggie.
I will try to educate myself about FB IN & OUT Parameters.
Thanx again
Hail the moggie.
Thanx again
Look for a book "Automating with Step 7" by Hans Berger
I can view all Produced tags list in the project from Logic-->produced tags, can someone help me on how to view the consumed tag list ? Thanks in...
1,601
Hello guys, So right now we are having some issues with a scanner. We are using Datalogix 8330 connected via RS232 and 2 of the wires are...
1,534
Hello All, I am beginner at Siemens S7 and I've met a problem. I need to find a location where a DB pointer is written but it seems like an...
1,775
Looking for some ideas here. I am trying to find a good way to verify that a rectangular part is orientated correctly. If you look at the picture...
4,658
