Low cost, medium range, serial radio modem
willpower100
May 2004
B.C. Lower Mainland Canada
81
Does anyone know of any low cost serial radio modems, medium range (under 1 mile)? RS232 or RS485, 2 way. Frequency hopping, spread spectrum would be nice.
I am looking at a low cost solution for a customer. I need to communicate with the PLC from the scale office to the remote plant.
Any ballpark prices would be helpful.
Thanks,
Willpower100
I used some about 8 years ago that were outstanding, but have been trying to remember the name for 2 years.
I got them through GE.
Ahha! Found Them!!!
http://www.data-linc.com
Don't remember Data-Link pricesw, some other brands are cheaper.
Rough range will be 200-1000 American. I would expect that it will run you 249-300 each for what you want.
I prefered the Data-Links 'cause I could plug them directly into the rack. I believe they had bricks available, too,
Many RF links are available with external antennas to increase range.
I used to buy surplus Motorola radio modems from MDM Radio in Melrose Park, IL (Chicago). They wete 460 mhz and worked super, a transceiver and modem, all was needed was RF connectors and a case.
No doubt, someone else will check in with another brand or two.
regards......casey
For whatever reason, I was "guested".
Anyway, an edit attempt here.
Not sure of the Data-Link prices. Others are in the 200-1000 range, with reliable ones around $300.
Data-Link has models that plug in like an I/O card, available for several major PLC brands.
regards.......casey
I'm a beginner in the automation field and I've set up an automation system connecting several devices (datalogger, radio, etc.) via Modbus RS485...
230
Hi folks, We have been working on our own controller after many decades of using the "big names". What would your ideal motion-controller be...
48
8,450
I was wondering if any one had an idea how I could implement an amperage reading to the plc. I have two PWM valves which draw about 3 amps...
1,637
Hi guys, May I ask if you know of any device with as few as 3 inputs and capable of ethernet connectivity? I have a project to monitor a number...
20
6,908
Greetings, I am looking for some ideas on low cost VFD's which natively support Ethernet I/P. Looking for 3 phase, 480V, 2h.p. and less. Just...
32
10,709
