LTF Laser distance sensor wiring
RodHappi
Nov 2020
saint-quentin
Hii!!! I'm new in automation and i have a Banner LTF Laser distance sensor (LTF121IC2LDQ). I want to connect it on a Allen Bradley PLC. Is the anyone who can show me how do to it please?
I installed a line with 2 of the LTF sensors. One 12 meters as yours, one 24 meters.
Lead 1 (Brown) is +24VDC
3 (Blue) 0VDC
2 (White) 4-20mA output (mA on mine, can be 0-10VDC if 12-U)
4 (Black) Optional relay output if programmed (not used on mine)
5 (Gray) Remote programming input - also not used, this is if you want to program it from the ground
See P 7:
Banner LTF Manual
EDIT: I will add programming the first one may seem like an overwhelming task! Good luck and don't give up.
3 (Blue) 0VDC
See P 7:
Banner LTF Manual
Hi I_Automation.
How you connect the LTF sensor to the PLC? You connect the 2nd pin to an analog inputs card?
Im a begineer on automation and im going to work with this sensor but i dont know how to connect it :(
Hi I_Automation.
The white wire is positive for the analog PLC input, tie the negative to 0V Common.
For just analog use the black wire is tied off and not used, otherwise it would go to a Sinking DC input.
Hi I have a yaskawa gp7 robot arm which I am going to use for machine tending with a cnc mill. Is it a good idea to buy a SICK laser scanner for...
271
Hi experts, I hope you're all having incredible days. I'd really like to utilize this sensor for a customer application, but the issue is that...
17
18,890
Good Afternoon , We have a few Datalogic Laser Sentinal Scanners . We have 2 that are pointing upward toward the ceiling . Roughly , within...
1,061
how to program a laser level sensor to a cooler tank with an AB plc
1,342
Hi everyone, I don't know much of PLCs but it happened that i need to connect Leuze AMS358i Ethernet laser measurement to Productivity 1000...
1,075
