Math conundrum
Most of us like mathematical problems.
What is the answer to this:
A mathematician finishes a large meal and says: √(-1/64)
He tried to say exactly the same thing about the electrical engineer who ate with him, but it wouldn't come out the same.
You can have the credit. Honestly, I wouldn't have got it if your answer hadn't been there. It was way too early for me and imaginary numbers.
Can someone show the working out for this?
It's way beyond my maths level but would be interested in learning how (and where) the 'i' pops up.
Its actually VERY easy to work.
To take the square root of a fraction, you just take the root of the top and the bottom.
sqrt(-1) = i (or if you are an Electrical Engineer its j since i is used for current). That is just a rule you have to remember.
sqrt(64) = 8.
Therefore: sqrt(-1/64) = i / 8.
√-1 = i
Or that's what I remember from my math classes over a decade ago.
Edit: Sniped, dam net going wonky....:D
I have an expression in a structured text routine of a Logix controller that looks more or less like the following: ResultInteger := Integer1 *...
421
This application has a motor with encoder feedback that drives a linear actuator that moves in/out, and is at roughly 45 degs from horiz. As the...
19
1,389
Hi all. First time programming a machine of this type. A center driven unwind feeding to a center driven rewind. No dancers or load cells, just...
37
4,924
Hello, Been a while since I posted , Still sucking air been a interesting 3.5 years the dreaded health with old age scenario. Back at it and had a...
2,072
Hello: Some time ago I wrote some basic code for a GuardLogix, in which I needed to add and subtract tags of LINT data type. When tried to use the...
3,766
