Melsec F1/F2 STL instruction
the stl instruction is used as part of a step sequencer and this function is still used in the Fx series and is explained in the Fx-series manual the stl instruction is basically the start of a ladder rung(connected to the main bus line) which is enabled in a sequence much like a cam timer ie 1st stl instruction operates when this operation is complete the next step is enabled and operates and so on untill the sequence is complete
Yes, thanks mel, I didn't have the manual at that time but I got one now and it has a detailed explanation.
Thanks anyways!!
Hi everyone, I have a small project for an industrial site entry gate system. It's running on an old Melsec PLC, and I have a new Shihlin PLC...
140
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
386
Hello! First time poster and a big PLC newbie so I am looking for some backup here. I have an old Mitsubishi FX-48MR that lost its program...
519
Hi I have a Melsec FX1S-20MR, which has been programmed. I would like to copy the program to a new FX1S-20MR? What are the possible ways to do...
630
Hello parky, goghie, Brian and all of you who kindly come to help when I get stuck. I cannot look into the clock issue that parki has written for...
862
