Messaging ML1400 to ML1400
sobrio35
Mar 2015
Vancouver, WA
Hi all,
Still pretty new to PLC's in general and brand spanking new to messaging. Trying to read from one ML1400 to another over ethernet. For now I would be happy just to read in one integer and build from there. I'm getting the error "Target node does not respond - DF1 DLE ACK/NAK timeout and DLE ENQ transmitted (ENQ retries exhausted)".
Should the target node be the same as the processor node under "controller communications"?
Very grateful for any help!
It sounds like you've specified one of the DF1 serial ports, not the Ethernet port.
For the Ethernet port, there will be a target IP address.
Yup! I switched to channel 1, the option for node disappeared, the MultiHop tab appeared and I was able to set the IP. First time messaging - hopefully smoother in the future, though I hear its a bit different for each device.
Thanks Ken!!
Good morning all. Does anyone know where a sample program is located to message data to and from a Banner VE Series camera from a ML 1400? I am...
32
12,150
Hello, I am trying to send descrete I/O data between 2 Micrologix 1400 PLC's using messaging instructions. Can anyone tell me if I have to use an...
2,348
Been a long time since my last post and I was just learning even what a PLC is. Since then I have been fortunate to work with some great guys and...
22
6,824
Hi All, I was wondering if it is possible to send ASCII commands via Ethernet messaging with a ML1400? I have to send instructions to and from a...
3,668
I am attempting to map registers from N10 in Micrologix 1400, to Modbus addresses at a customer’s PLC, over an Ethernet connection. All the...
3,940
