Micro820 aka disaster
HawkEye87
Sep 2018
Cork
Hi guys
I am new to the threads and relatively new to the world of PLC programming.
During a recent programming session, I was using the Micro820 in DHCP mode when I blindly tried to configure a static IP address. In doing so and while connected, I managed to remove all IP address settings from the controller and now I can not connect, the ENET light is not showing any signs of life when I plug in (it should show green even without config) and windows diagnostics is telling me that my device does not have IP config.
While connected through DHCP, I changed my computers adapter settings to suit the 169.254.xxx.xxx address, then I changed the DHCP setting on CCW controller options while also unchecking the Port settings Disable button.
I have read that I can communicate with the controller through USB, but the recommended route is to use the LCD add-on.
Can somebody tell me if there is another way to connect directly through the comms port. Thanks!!
Thanks Tarik1978
But I have previously used this controller with know problems and I understand the connection process, somewhat.
Now I am looking at a re-config through RS232 DF1
I really do not understand why the controller is giving this problem
Thanks for the reply
Welcome to the PLCTalk forum community !
Generally I set up my computer for a static IP address first, then use DHCP to get an address into the controller temporarily. As you've seen, leaving your computer in DHCP mode and allowing it to fall back to an automatic private IP address (the 169.254.x.x) can leave you chasing your tail.
I independently went searching for the Wilborne video on YouTube because it's so instructional.
https://www.youtube.com/watch?v=cdpkNAhnmCQ
But it's probably easiest to set that aside.
If you have genuinely disabled the controller's Ethernet port (I did not realize that was possible) then the best way to get it reset is to connect to the RS-232 port.
It's a screw-terminal port but if you have an RS-232 port available (built in or USB adapter) you can simply cut the end off a cable, verify the pins 2,3,5 conductors, and wire it in.
Thanks Ken
I have verified that I have indeed disabled the ethernet port, through using a different cable and also using a different laptop.
Great way to finish off a Saturday night!!
Tomorrow I will have a crack at the RS232 config, I have a couple of cables around somewhere.
Here is a very simple way of resetting the IP address of the Micro800 series Plc's with ethernet.
Get an SD Card, format.
Now with wordpad create a file called "configmefirst.txt"
This file should contain these lines.
[PM]
[IPA=192.168.2.101]
[SNM=255.255.255.0]
[GWA=192.168.2.1]
[END]
Copy this file to the SD card and insert into the plc then reboot the Micro it will now be programmed to the new IP address.(Be sure to remove SD after)
Be sure to follow all spacing as it is shown, if a single space is different it will not work.
Hi Guys
I have successfully regained Ethernet comms!! I ended up using the rs-232 protocol.
Damica1 : I did try your method first but no joy, I entered the text word for word and also found a slight variation of your script on Rockwell support, but neither worked after repeated re-boots and new .txt files. I am eager to use this method in the future so I will try to set a new IP now that I have re-enabled my Ehternet port.
Thanks for the help guys, hopefully I can return the favour one day!!
I have a problem with a 820-LC20-20QBB, I was doing a download and CCW froze, and became unresponsive. After a while it responded that the download was not completed. However thereafter the plc was faulted with solid red led. I powercycled , and noted that the ENET and SD remain green for 2.5 minutes but never go to run mode , after this time elapse it goes to fault solid red led. tried ip force , firmware flash all failed. any help would be appreciated.
sounds permanently dead.
I’m trying to read values from a device that can either send registers as 32 bit or a pair of 16 bit but if I understand right, the micro can only...
26
831
Hello, I set up my Micro820 with a basic mapping. When I try to run a script to read the addresses I get errors for illegal addresses...
173
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
910
Hello, I am using a AB Micro820 PLC, via the SD card I want to update the PLC program (not FW). First I created a text file on the SD card with...
302
Hi New to PLCs, up until now I have played with smart relays and the siemens S7-1200 line with TIA. I am trying to get a AB Micro820 to talk to...
308
