Micro820 and Intouch 10.1
muusic_man
Nov 2008
Delaware
148
I normally have no issue getting data from my plc's. In this instance I can't for the life of me get the correct I/O Server/Settings to talk to it. The Micro820 is networked and I can see it in RSLinx. I can connect to it and program it remotely with CCW software, but when I attempt to set up the I/O server I get no data back to Intouch.
I have tried using DASABCIP, DASABCIP, DASMBTCP, DASABTCP and FSGATEWAY connecting to RSLinx as the OPC Server but I can't get a value back to Intouch.
Does someone have real life experience with this that would be willing to share exactly the server/settings that they have used to get this going. I have spent a large amount of time trying to get this to work and the frustration level is at an all time high.
Thanks in advance.
I have never used Micro820 with InTouch, but have used 820 with Microsoft HMI. It worked well with the MBTCP .NET class. Download one from www.controlsystemtools.com & try it for troubleshooting your system. It will show you the xmitted & received messages. That will prove or disprove one of the 2 , where the problem is. Cheers.
I’m trying to read values from a device that can either send registers as 32 bit or a pair of 16 bit but if I understand right, the micro can only...
26
833
Hello, I set up my Micro820 with a basic mapping. When I try to run a script to read the addresses I get errors for illegal addresses...
175
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
912
Hello, I am using a AB Micro820 PLC, via the SD card I want to update the PLC program (not FW). First I created a text file on the SD card with...
304
Hi New to PLCs, up until now I have played with smart relays and the siemens S7-1200 line with TIA. I am trying to get a AB Micro820 to talk to...
309
