Micro820 cip serial with radio
cockrell960
Aug 2014
Texas
I am trying to get a contrologix l62 to message a micro820 using the serial connection through a mds 9810. I am not having luck. There are multiple nodes on the serial network and I believe that is my issue since the mds 9810 runs half duplex but the serial on the micro820 runs full duplex. What gets me is that you can set a node number on the micro820 which would make me think it can perform at half duplex.
I am using a cip data table read pointing to the correct node.
We previously had a micro1200 which did half duplex.
Is there any way to make it work??
Thank you
I’m trying to read values from a device that can either send registers as 32 bit or a pair of 16 bit but if I understand right, the micro can only...
26
825
Hello, I set up my Micro820 with a basic mapping. When I try to run a script to read the addresses I get errors for illegal addresses...
172
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
906
Hello, I am using a AB Micro820 PLC, via the SD card I want to update the PLC program (not FW). First I created a text file on the SD card with...
300
Hi New to PLCs, up until now I have played with smart relays and the siemens S7-1200 line with TIA. I am trying to get a AB Micro820 to talk to...
308
