Micro820 DHCP configmefirst.txt
RMore
Dec 2011
Kenmore, NY
64
I have a project based on the Micro820. My project does not have an HMI, and the application is locked. In order for our customer to reconfigure the IP setting from the default DHCP to a static IP he needs to use a SD card with the configmefirst.txt file. My question is, once the customer does this, is there a way for him to set the IP configuration from static back to DHCP ?
I’m trying to read values from a device that can either send registers as 32 bit or a pair of 16 bit but if I understand right, the micro can only...
26
831
Hello, I set up my Micro820 with a basic mapping. When I try to run a script to read the addresses I get errors for illegal addresses...
173
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
910
Hello, I am using a AB Micro820 PLC, via the SD card I want to update the PLC program (not FW). First I created a text file on the SD card with...
303
Hi New to PLCs, up until now I have played with smart relays and the siemens S7-1200 line with TIA. I am trying to get a AB Micro820 to talk to...
308
