Micro820 Failed Downloads lead to a bricked unit
This was using verion 4 or 5 of CCW so it was several years ago. I could download to a PLC and brick them just by downloading. The only way to get it back was controlflash. My apprentice never had a problem bricking one. The exact same program, i could brick it and his would work. The difference was the button we used to download to the controller. I used the dropdown menu and he used the direct button. Everytime it made a difference. The AB distributor didn't believe me until we showed him over and over with his PLC.
that's pretty believable considering the BootP button/right click difference that people have known about for years.
so if it was bricked, how were you getting a connection to communicate with controlflash?
I think we had to use DF1 or modbus on the serial port.
Yes, unfortunately the DF1 driver through rs232 is not working either. It just doesn't get far enough into the boot to activate any communcations. tried all possible settings, multiple usb-rs232 adapters, etc etc. I believe i've tried every possible outcome to get it to work.
short of opening the case and trying to get to the pins on the ICs (which i wont do so we can get our warranty on it), there isn't much left to work with.
Yah, thats not good
I have maybe 500-700 or so that I have programmed and never had an issue BUT with 98% of them I use the flash drive, now that said... I have not had any customers tell me that they had an issue either
Is it the same PC that did the other one also?
Yah, thats not good
Same PC. I can't imagine it would be an issue related to one specific pc though. a different coworker has had some issues before with download errors, but never so bad it wasn't recoverable. If it was myself that had the problem I'd have a bit more direct info as well as screenshot of the errors, but oh well.
Hello,
I got the same situtation, the Micro820 is bricked.
Same LED's stays On, and after a little while the Red fault button comes On.
Tried everything you tried, like SD card, RS232, but nothing worked.
Did you manage to find a solution?
Hello,
The solution has been this so far.
1) Return the unit to whoever sold it to you and ensure you have cash in hand.
2) Never suggest or sell Micro 800 series again.
In short, no, nothing worth putting time into to find out why it fails to run after a simple download.
Please enlighten me…
Surely, this isn’t a secret trick to make bootp more reliable .?
It's funny, but not like a Ha-Ha funny....
Instead of fixing the problem, they just put a technote out to address it.
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/49280/loc/en_US#__highlight
ID: BF4486 | Access Levels: Everyone
Unable to Disable BOOTP/DHCP Using the BootP-DHCP Tool
* Right-click on the <MAC address> in the Entered Relation list and select Disable BootP/DHCP.
one of the many things to try that they list if it doesn't work.
I’m trying to read values from a device that can either send registers as 32 bit or a pair of 16 bit but if I understand right, the micro can only...
26
818
Hello, I set up my Micro820 with a basic mapping. When I try to run a script to read the addresses I get errors for illegal addresses...
170
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
904
Hello, I am using a AB Micro820 PLC, via the SD card I want to update the PLC program (not FW). First I created a text file on the SD card with...
298
Hi New to PLCs, up until now I have played with smart relays and the siemens S7-1200 line with TIA. I am trying to get a AB Micro820 to talk to...
305
