Micro820 to Micro820 MSG_CIPSYMBOLIC
tdcolumbia
Nov 2022
Missouri
Can a single MSG_CIPSYMBOLIC function block be set up to write multiple REAL values (setup in an array)?
I've read through a lot of help files and such, but I can't find anything say YES or NO.o_O
I’m trying to read values from a device that can either send registers as 32 bit or a pair of 16 bit but if I understand right, the micro can only...
26
829
Hello, I set up my Micro820 with a basic mapping. When I try to run a script to read the addresses I get errors for illegal addresses...
173
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
909
Hello, I am using a AB Micro820 PLC, via the SD card I want to update the PLC program (not FW). First I created a text file on the SD card with...
301
Hi New to PLCs, up until now I have played with smart relays and the siemens S7-1200 line with TIA. I am trying to get a AB Micro820 to talk to...
308
