Micrologix 1000 upgrading
amihan1970
Aug 2008
Illinois
Hi there, my micrologix 1000 is 1761-L16AWA. Is there a possibility that I can add an analog module(4-20mA)?if its possible can you give the equipt. model?thanks
The simple answer is no
Welcome back to the forum. I'm glad to hear you are getting some use from that surplus controller.
This is the "practice posting" section; you will get better results in the main forum.
The MicroLogix 1000 controller is not expandable and you have one of the smaller units that does not have analog I/O.
There are larger MicroLogix 1000 controllers that include some onboard analog channels, but even those controllers are not expandable. The MicroLogix 1100, 1200, 1400, and 1500 controllers all have expandable I/O.
Many years ago there were a couple of companies that built analog-to-frequency converters that could be connected to small PLCs that lacked analog I/O. The names Calex and SensorPulse come to mind.
But I do not think that can work with your 1761-L16AWA because it uses AC inputs, which because of the frequency of the alternating current signal cannot sense quickly enough to be used as accurate frequency counters.
So the simple answer is that no, you cannot add analog inputs to your 1761-L16AWA MicroLogix 1000 controller.
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
144
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,261
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
989
Hello All I am trying to convert a ML1000 program for use in a ML1400. I didn't create the original program & documentation is non existent...
4,417
Hey Folks, I have a customer with an older machine that is controlled with a MicroLogix 1000. The machine just quit working. The power light is...
22
10,581
