millivolt offset
Jan 2003
Michigan
490
Hey all. Another question. I have a O2 sensor that is putting off a volt signal. However, I need to adjust this voltage down by 1 volt for the controller. Is there some kind of signal conditioner or offset card that can do this?? Thanks.
Matt
does this happen to be 1/5 volt?
if so what is problem?
all meters have a jumpoer to set it to 0/5 volts or 4/20 mA to 0/20 mA.
if not use converter if really needed. if going into plc use rescaler.
as shooter says, it could be the standard offset from a 4-20 mA signal.
You probably dont need to use a hardware signal conditioner at all.
If PLC: Program your own scaling function to accomodate zero and span.
If PID Controller: Study the manual carefully, the chances that it has an input scaling function allready is 99% ;)
Hi, Does anybody know of an industrial wireless (2.4GHz) which will transmit a simple mV signal? I need to input a 0-15mV signal at one end...
4,170
Guys, Does anyone know of a Millivolt source unit that is pretty accurate for simulating a load cell that is working off of 0-10volt? Eli
2,897
Hi, Been a long time since I have been on here. I have a 1771-IFM Fast Millivolt card that I just can't seem to get to work. I am having a...
17
5,240
We have some Emery Winslow hydrostatic load cell systems which measure weights of large blenders and send a millivolt signal (16mv, 6 wires) to a...
10,320
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
100
