Millivolt wireless transmitter
DLMUK
Jun 2013
Southampton
311
Does anybody know of an industrial wireless (2.4GHz) which will transmit a simple mV signal?
I need to input a 0-15mV signal at one end, wirelessly transmit this a short distance, and output the 0-15mV at the other end. Distance is <100m.
Had a scout around but I cannot find anything.
Thanks,
Thanks,
Do you really need to keep the signal level at 0-15mv? Why not use a transmitter to change the low voltage (15mv) to 4-20ma, or 0-10vdc that is easily handled buy a wireless transmitter, in and out of receiver. At the receiving end either convert back to 0-15mv if it really needs to be at that potential.
What is the end use of the mv signal? Load cell for a scale? Or can the output higher potential signal be used directly like into a PLC or data recorder?
The other end has a load cell display which has a maximum input of 15mV. I didn't want to over complicate having multiple devices doing many conversions. I have found these which I may try...
https://theloadcelldepot.com/shop/wireless-scales/wireless-scale-system/
Guys, Does anyone know of a Millivolt source unit that is pretty accurate for simulating a load cell that is working off of 0-10volt? Eli
2,897
Hi, Been a long time since I have been on here. I have a 1771-IFM Fast Millivolt card that I just can't seem to get to work. I am having a...
17
5,240
We have some Emery Winslow hydrostatic load cell systems which measure weights of large blenders and send a millivolt signal (16mv, 6 wires) to a...
10,323
Hey all. Another question. I have a O2 sensor that is putting off a volt signal. However, I need to adjust this voltage down by 1 volt for the...
2,940
Hello Y'all, I was wondering if there is any standalone solution to replace the ethernet cable to connect to a PLC? like perhaps a "Dongle"...
26
2,361
