$Minute Script
Ones_Zeros
Feb 2014
at work
367
Hey Guys
I have several scripts to write in Wonderware & I was concerned about the limit of lines in a script. I have been placing them
under in the Data Change Script by using the variable $Minute.
This is a built in variable within Wonderware that runs the script each minute.
My question is this, I know there must be a limit on the number of lines that a script can be.
Is there a better variable to use or how could I configure these scripts to run each minute without using the $Minute variable?
thanks,
I use the $Second and $Minute all the time with no problems. If you want to clean up the code put some of your most common script in a Quick function and then just call that every minute.
Agree with this. Use quick functions to keep things tidy. I prefix the quick function name with Min_ so i they are super easy to identify
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
111
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
102
Hi All, I'm keep getting double quotes in between selections rather than the beginning and the end. Here's the script and please help to find...
801
Dear guys, I am not a programmer but I can do simple things myself. I'm stuck with the following. if I want to extract a value from my rx3i...
46
4,772
Hi guys, I'm busy on the migration of old 3G/RS232 modems to 4-5G / Ethernet modems on about 200 pumping stations across the country. To...
439
