Mitsubishi Got 2103
Rocboni
Mar 2018
Scotland
I have been playing about with a Got and managed to program various functions and buttons however I’ve not been able to trigger a screen.
I’d like to trigger a flashing red screen with “Emergency stop” written on it using a input. I have tried playing about with the screen trigger action but can’t get it to do anything. It need to flag this up regardless of what screen it’s on.
Is anyone able to explain this to me? I’d this possible with this HMI?
Go to the "Screen Switching/Window" in the "GOT Settings" (System Tab), and set your Screen Switching Device for the Overlap Window to your PLC Device. Set the value in the PLC to be the screen number of your Window Screen (not base screen) that you create.
An alternative is to create a pop up i.e. box, Text Box where the visibility is enabled by the alarm bit (copy to all screens). To be honest I hate pop up things that cover most of the screen, If I need to display an alarm or Message I set an area on the screen (tends to be top or bottom) that will display the message (flashing in red), It is usually large enough to attract attention but not too large to obliterate other information. Another point you could do the logic that if a mute key is pressed, this hides the message for a time to allow operator to look at the underlying screen.
Is there an output or something that is similar to a screen saver, but you can use in the plc to know when the user is actively using it...
507
Hello, I have a GOT 2000 that is dead and only have a GOT 1000 spare at the moment. I have converted projects up from 1000 to 2000 before, but...
799
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,318
I am trying to connect GOT-A953-tbd HMI with Nittoku NSC30. Actually, earlier GOT-A953-tbd HMI was used to communicate with Nittoku NC350 and it...
1,392
Good day all We had a GOT1020 HMI installed but has failed recently. We then Bought a GOT2103-PMBD. I need to download our old software to this...
1,426
