Mitsubishi Timer status bit
elfrider
Nov 2015
Midlands
32
I'm after finding out what the Mitsubishi equivalent of the .TT bit in an Allen-Bradley PLC is (i.e T4:0.TT or Timer1.TT).
If using a Mitsubishi type timer, say T0, we can use TS0 and TN0 but is there a Tx0 that is set when the timer is actually timing? How about with an IEC style timer?
Up till now I've had to either duplicate the logic in front of the timer AND NOT TSx (timer conditions true but timer not done) or use a Timer Value > 0 AND Timer Value < Timer Preset. Either way seems very long winded compared to how it is done in Logix 500/5000.
Can't you just put an 'M' relay in parallel with the timer coil (on when it's timing, off when it's not)
If the rung conditions remained true after the timer has finished timing this M coil would stay on which wouldn't be the same as 'timer timing'. I'm pretty sure this functionality could be achieved by using the ENO output from the timer itself.
Hi, does anyone have experience with the Off Delay Long Timer function in GX works 3, I need a PV greater than T#2147483ms If I use Long Timer...
1,235
Its been a while since I've worked with a mitsu. In regards to Timer register reads and writes: Does it read the accumulator and write to the...
2,311
Dear frnds......... I m facing a problem in my project in mitsubishi plc fx2n 80mr. i want to back up my relay output . i mean i want them active...
4,750
Hello, I'm trying to figure out what the Timer and Counter data types can be used for in Mitsubishi GX Works2. I can make Global Labels and...
5,880
Hello all, I don't know if its the football, the beer, or me, but I cannot figure out how to add a timer or counter in a rung using GX Works 2...
1,753
