ML1500 MSG control code
Mar 2005
49
Hi Everyone.
I am working on a quasi DSC project. I am using DeviceNet. I have 1 Master(HOST) connected to a Panelview+ 1500 and about 12 slave nodes connected to Panelview 300's.
Through the Hosts HMI, attributes in a slave can be change. This is accomplished simply by selecting a node and turning a feature on/off or changing some numerical value. In my code I using the node selection and the enter bit to determine/trigger a message being sent to the selected node.
I used the example given in the ML1500 instruction set reference manual for "Enableing the MSG Instruction Via User supplied Input",
MSG to node 1 has been requested, latches COMM BIT
Node1 COMM1_L_U_OFFSET1
B3:4/0 MG112:0/EN B3:21/0
------][--------]/[---------------------------------(L)--
Intiates message being sent
COMM1_L_U_OFFSET1
B3:21/0
------][--------------------------------MSG MG112:0----
when message is done unlatches Comm bit
MG112:0/DN COMM1_L_U_OFFSET1
--------][------------------------------------------(U)----
MG112:0/ER
Clears message request bit
Node1
MG112:0/DN B3:4/0
-------][-------[ons]------------------------------(U)-----
Alright, everything works great...messages get sent, no errors, happy go lucky.
My problem is that when I am viewing this online the DN and EN bits remain high after the intial msg transfer. I looked at that timing diagram in the book and the EN bit should go low after the DN bit goes high...this dosen't happen.....Any suggestions or comments? Has anyone else used this example code before?
Thomas
Hi all, I've worked through messaging in both direction in the CPX and ML1100 with help from you guys. Which is much appreciated. I have a...
4,727
I am trying to message from a SLC 5/05 to a ML 1500 on a network. I need to read from the ML to the SLC 5/05. Here is my setup. SLC 5/05- IP...
4,660
Hi all, PLC : Micrologix 1500 lrp HMI : Renu FP3070 TN I am a beginner in the plc world. I am trying to connect the renu hmi with ML1500 lrp in...
768
Hello folks, Hope everyone is doing well. I am a beginner at working in analog signals with PLC Analog module: 1769-IF4 ( 4 analog inputs ) PLC...
1,361
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,230
