TimWilborne Lifetime Supporting Member Join Date Oct 2005 Location Roanoke, VA Posts 2,210 Nov 8, 2006 #16 Your right Contr_Conn. I got ahead of myself and was thinking about Micrologix to Controllogix
dluebbert Member OP D Join Date Nov 2006 Location Kansas City Posts 14 Nov 8, 2006 #17 messaging to the eni using the same way as to the slc did not work, responds with illegal command from local processor.
widelto Member Join Date Jul 2005 Location Barranquilla, Colombia Posts 3,392 Nov 8, 2006 #18 Try this from knoledgebase, maybe will help you.
dluebbert Member OP D Join Date Nov 2006 Location Kansas City Posts 14 Nov 8, 2006 #19 That is useful info and i will prob use it. but right now i am trying to msg from the controllogix to the micrologix via the eni.
TimWilborne Lifetime Supporting Member Join Date Oct 2005 Location Roanoke, VA Posts 2,210 Nov 9, 2006 #20 What type of message are you using? What slot is the Controllogix processor in?
dluebbert Member OP D Join Date Nov 2006 Location Kansas City Posts 14 Nov 9, 2006 #21 The processor is in slot 0. i have tried the cip data table read and the plc 5 typed read. the enbt is in slot 1. I have the ip address of the enbt in node 45/145 of the eni. Im using the eni's ip in the msg path.
TimWilborne Lifetime Supporting Member Join Date Oct 2005 Location Roanoke, VA Posts 2,210 Nov 9, 2006 #22 It needs to be an SLC Typed Read
dluebbert Member OP D Join Date Nov 2006 Location Kansas City Posts 14 Nov 9, 2006 #23 Thanks i think its all working.
