MSG Path
J2009
Dec 2016
South Carolina
23
I have a compactlogix L45 with an enbt module on network segment 130.90.168.51.
I have an ethernet cable going from that module to a phoenix contact switch, then to an N-Tron 716tx switch, then to a controllogix enbt module 130.90.71.5
I am trying to send a message from the compactlogix to the controllogix with a path 1, 2, 2, 130.90.71.5, 1, 0.
When I enable the message I get an enable waiting and an error code 16#001f extended code 16#0000_0204.
What could be the issue?
Thanks,
I need assistance with writing a logic for sending data from a Station PLC using 1 MSG instruction to an AGC PLC in every cycle using a CIP Data...
586
Hey Guys Having some trouble again with message path, I thought I had these figured out but I've not been able to get this one working. I...
590
I got an ANC-100e DH+ gateway for some remote work via Cell modem. It works fine and I can program the PLC5 on the far end just fine, but I can't...
2,636
i need help constructing the message path to read a SLC5/04 with a L33ER compact logix via a control logix DHRio card compact logix ip...
1,186
Hello, I am using a Compactlogix 5380 PLC and need to read values from a few existing PLC 5s, other Compactlogix PLCss, and a few Controllogix...
4,324
