MVI46_GSC Error on M0/M1 Files
delt
Mar 2006
Chih
19
I try to implement a MVI46-GSC module in Slot 6 of A10 Rack but When I try to Write or read by using the M0/MI files the RsLogix Display an
Error :Unconfigured 'M' file address reference (#M0:6.0)
In the Advanced I/O Configuration the M0 Lenght and MI Lenght fields are not permisible to modify,
How can I edit this field M0 Length = 400 and the M1 Length = 300 as shown in the MVI46_GSC _User Manual?
I appreciate yor help.
I've configured 5 of these modules in the last 2 years. Are you setting the module configuration through the SLC 5/05 serial comm port or are you going through the module ports? Are you using a CP3 cable from the computer to the SLC? If the SLC 5/05 CH1 port hasn't been changed the it's configured from the manufacturer for DF-1 communications. Are you offline? Configuring the module through the SLC comm port is the easiest way, also, you need to be offline to set the M0/M1 file length. Then download the configuration with the ladder file as you would any other program. Hope this helps.
Hi everyone, I have setup a Prosoft MVI46 GSC, how do I get the word "scale" to a computer via ascii? The module is setup and communicating with a...
5,584
Hi need help with an application that I working on and I'm having trouble in manipulation of a barcode which I need to extract data from...
7,967
We have a MVI46-GSC Prosoft module and are going to use it to receive data from a Bizerba dynamic rail scale and transmit data to an Okidata...
2,788
I am trying to use Prosoft's MVI46-GSC generic ASCII card to receive information from a Datalogic barcode scanner. I'm having problems getting...
2,554
Has anyone here attempted to connect Ignition to a SLC with a Prosoft MVI46-DFNT? I am able to do read/writes to the card from a compactlogix but...
1,467
