Need help on Citect Trend calculation part..
KevinPhoa
Jul 2007
malaysia
hi,
I'm using citect 6.10, need help on trend calculation part.
I need to get the trend value calculation as below:
Reject Value = sum up all the rejection value. (Value that less then minimum and maximum range)
Average = average of all the value (not include the rejection value)
Standard deviation = standard deviation of all the value (not include the rejection value)
There will be minimum and maximum line for the trend which if exceed the both line is considered as reject value. i've been facing this issue for 4 days time already, and still couldnt get it. Can anyone help me on this, or anyone have sample on this so that easy for me to understand how the function use works. Thank you guys..
hi kellian,
Thanks for your respond. What you mean by looking at Accumlators? actually i was quite new in citect. I've been tried using trngettable function to get the trend value. But still couldnt :( Do you have any running sample that i could refer too? A program that using trngettable and tablemath function? :p
Thanks ya...
28
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,671
Hi all, my citect program write all the alarms to a xls file when i open that excel i will run a marco automatic and i can see a bargraph of all...
3,930
I build the project in Vijeo Citect 7.10. That was fine when run in "No Networking" mode. But when I set to "TCP/IP", the problem occured, I can...
1,900
Can anybody please provide me help on citect by some demo examples so that i may be able to learn citect . How to use VBA in Citect and what is...
17
7,821
