Need help on Citect
Andrew i can ping the micrologix quite easily and as suggested i did put all the things mentioned in ur email . When system goes into the runtime i always get a hardware alarm " PLC server I/O device offline" ??????
Have you tried shutting down RSLinx?
Worked for me.
(Using same serial cable for the communication with RSLogix and CitectScada7.2)
32
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,672
Hi all, my citect program write all the alarms to a xls file when i open that excel i will run a marco automatic and i can see a bargraph of all...
3,930
I build the project in Vijeo Citect 7.10. That was fine when run in "No Networking" mode. But when I set to "TCP/IP", the problem occured, I can...
1,900
hi, I'm using citect 6.10, need help on trend calculation part. I need to get the trend value calculation as below: Reject Value = sum up all...
3,647
