Need profibus GSD file for Bubenzer CMB2-SB brake monitor
smartatuls
May 2013
India
30
Hi all,
I want configure Profibus-DP nodes of Bubenzer CMB2-SB brakes which monitors the brake status and sends signal to PLC(profibus master=IC695PBM300). I don't have the GSD file to configure it in my PLC project hardware configuration :oops:
If anyone is having the GSD file please share.
Hi, I'm using PPO1 to communicate with MM440. I only need to read and modify MM440 parameters, so i sucssesfully use PKW mechanism. I don't have...
1,305
Hi all I want your advice for my problem : I have two PLC control systems , first is an old one and I use an Intouch Scada system to monitor and...
3,401
Hello, I have some basic questions to ask about Profibus. Tt will be a little long to explain all, but I prefer giving all details to help people...
2,727
hi to all i need a solution on following matter i have a profibus network having siemense s7 plc one pc and it has an ethernet port to be...
2,018
Hiya, In the past I have worked with AB PLCs, Citect, DH+ but I have recently changed jobs and struggling with the changes. Sometimes dont know...
1,676
