Omrom CQM1 Cpu 21
whtrader
Aug 2006
KL
37
Need help here. I am trying to connect to Omrom CQM1 cpu 21 using a serial cable. I am using CX programmer 5.0. I have scanned the baud rate using the network configuration tool but with no success. I believe what I am missing is the configuration for the data format eg Databits, Parity and stop bits. Is there a way to determine what configuration have been set on the plc? Thank you.
Double click 'Settings' from CX Programmer then click the 'Host Link Port' tab.
The programming cable is a simple one, with the connections in the manual (2-3, 3-2 and 5-5).
Use the default parameters...
Have you cheked if the switches in the PLC are correct?
Connection to Omron
gtsuport said:
Sorry, pin out above is NOT correct. Try this link.
Omron 9 pin cable
Hope this will help.
You're absolutly right.
Sorry for the mistake.
Here's the connections:
PC: (DB9 female) PLC: (DB9 male)
1,6,4 - Shunt
2----------------------------- 2
7----------------------------- 5
3------------------------------3
8------------------------------4
5------------------------------9
Hello members, Just wondering, is it possible i want to upload program (backup) from PLC CPU Omron CQM1 to laptop during RUN mode key selection...
1,855
Hello everyone. Is the PLC CJ1M CPU13 capable of online editing? Or only downloads that will stop the PLC? Thank you.
346
Hello everyone, A client has asked us to change a bit of logic on his PLC. Our job is to put a new transmitter, reading it with Modbus RTU. He...
392
Hi, I just bought a used Omron CPM2C (with CIF01). It is password protected and I don't know the password. Is it possible to clear it, so that I...
2,079
hello all.... i been working with wincc HMI which connect to Omron PLC ch200he.. i facing a problem that ..i cant connect more than 1 HMI to...
2,439
