OMRON-C200HS -Search function
GanShan
Jan 2006
Singapore
Hi
Am having OMRON c200HS cpu 21 PLC , I ve created a a library of DM which contains
Differnet type of products to run . these types are Character strings (WSH67RTY_X) every string take about 10 Data memory(DM1000-Dm1009).
I ve selected one type using a bit switch through touch screen.Now I use barcode scanner to scan the type name and stored in a separate DM.
Now I wouldlike to Compare the Scanned type name and the selected type name .
Is there any special instructions to use .....
CMP just compare 1 Dm only ...?
Among 50 types how to bring out the selected data memory.
Can any members can help
As IO rack stated, have a look at the tutorial he posted.
Do you understand the concept of pointers and indirect addressing? If so, with a little bit of reading, you should able to interpret the example, and implement it in your application.
If not, do some searches on this site, on indirect and pointers etc, and then come back with your questions.
thanks all
i ve stored my data starting from DM2000, in a 10 nos interval , so i whenevr a bit activated i just add 2000 and multiply 10 to get the corresponding datamemory ..
I ve another question , how can i use the PLC clock in my program,
i wanted to turn on some output on some particular day and month of the year .. how can i tap from plc clock ? pls advise
Hello, first off I am not a PLC programmer so bare with me.... We have specialized glass lathe that has a C200HS PLC system that has probably sat...
18
2,180
Saludos amigos. Tengo una impresora comexi modelo FS1500, la impresora usa intouch 7 en Windows 2000, viene con un PLC Omron C200HS, también usa...
1,100
Hello, New to this forum and to Omron. Really hoping someone has some input or advice that I haven't already tried. Have exhausted all I could...
1,407
Hi folks Looking to connect an Omron C200HS to Kepserver using the Peripheral port and the CQM1-CIF02 programming lead. I want to try and use...
1,480
Hi all, I have a few old Omron SYSMAC C200HS CPU01 PLC's and am trying to learn what is req'd in order to communicate with them. I have an...
2,341
