Omron Syswin and Win XP - Error
Orn Jonsson
Apr 2002
Boise Idaho
125
Just put XP on the laptop a few months ago and this morning I opened Syswin (Ver3.1)for the first time under XP, and this is the error message I got.
Cannot find Syswin Dongle.
Check HL-Server is loaded for network connection
Any Ideas why the computer is all of a sudden no seeing the dongle on the paralelle port?
OJ
Yep! Same as NT - you must have been running 95, 98 or ME before. Run HLS_NT.EXE that can be found in the Dongle sub-directory to install the dongle.
Next error is: "Hardlock driver is not installed correctly" message 14
Any pointers on that one?
Do I really have to install the software as "DEMO" in order for the HL server to work?
OJ
Syswin was originally written for 95/98. NT and XP do things differently. Yes! Install as demo and then run the hardlock program. There is a text file in the Dongle directory about the issue.
Is there a way in syswin to see if any bit in a word is on? I am doing alarms. I have about 12 alarms on one word. (200.00-200.11) is there a...
1,907
Hi All, Just a quicky....I am using Omron SYSWIN 3.4. No problems there but a customer has asked me to log 3-4 analogues coming in and export the...
1,672
Hi I am a beginner of PLC. I am running Syswin 3.4 on C200H PLC. I am trying to use counters a Timer. The reference says that when counting or...
6,861
Hi, I need a little help with something that will probably be very easy and obvious to anybody who uses the Omron PLCs with Syswin. I usually...
3,074
I am trying to re-arrange a long ladder diagram in an Omron CQM1 plc into seperate blocks for clarity using Syswin 3.4 Problem is that only the...
2,303
