OT 0-10V question.
Soggy Canuck
Jan 2008
Vancouver
229
Has anyone run across a 0-10V isolator/amplifier that is capable of supplying 70mA of output current on a 0-10V signal?
The existing cct uses a 5K pot to drive a 555 timing chip which in turn drives a power transistor with a filtering cap to generate a 0-10V signal. This in turn drives into OEM DC drives (8 of them) as a master speed signal. These drives have a separate pot input wired for fine tuning. I have 5 circuits like this that the customer wants to follow a machine speed circuit.
Given that there are 40 drives involved, it would be most economical to replace the existing 555 timer cct's with 5 independent 0-10V amplifiers that I can feed from a main machine drive analog output. Assuming that I could find one capable of supplying the 70mA needed to supply the 8 connected drives.
I'm beginning to suspect that there's going to be some breadboard work needed for this.
almost any transistor can deliver this 70 mA.
and or a simple opamp, will mirror the input just fine.
like a 741.
I agree with what you say, Shooter. It's just that having fought my way through enough handbuilt cct boards over the years, I don't like leaving "gifts" behind for the next poor schmo who comes behind me. I'd much prefer an off the shelf solution if at all possible.
a shelf solution will not be serviced in 5 years, and is way more complex as needed.
so prefer to make my own stuff, and yes document the works.
Hey guys, I have a level sensor, Flowline LU20, for a tank we have here. It is a simple 4-20mA output. However, the company that installed the...
19
14,569
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
288
I have a SX2 plc and i'm getting 0-10v analog signal,but i need 10bar analog output in 0v can someone explain how its done
554
We have a 4 wire 0-10V analog OPT2012 (Time of flight distance laser) from Wenglor that we're experimenting with. We are able to teach the laser...
560
Hi All, Not strictly PLC, but I'm sure someone works with this stuff and might be able to point me in the right direction. I'm designing a...
1,055
