OT Counter unit replacement
Jezz
Dec 2002
Kendal
399
Hi All,
I'm trying to replace an old counter on a sample line, should be simple but the old counter flip flops its out put i.e. you set it to the desired limit (thumb switches on the front) then it counts up to that value and switches on its relay out it then resets the count and starts again leaving the output on until it reaches it's set value again then it switches it off and resets itself and starts again.
I'm trying to find a replacement but I'm struggling, any one know of a counter that can do this?
Hi All,
do a google on the Red Lion CUB
So if your counter is set to 20, then the output is on for 20 counts, and then off for 20 counts?
______Off___________---------On--------_________Off________----On-... etc.
How about using the Moeller Easy or other "programmable" relay?
Program your own functions if you cannot find an exact replacement!!
Hello, I am looking for a counter and tachometer combination unit. The unit should meet the following specs: 1/600 Hz min frequency (1 cycle...
3,223
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
121
Hey Everyone, After reading a lot on this forum and elsewhere I see not many are fond of the 1794-VHSC module. I can see to a degree as I was...
186
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
92
Hi all, I am working with an incremental encoder (ABZ signals, 360 ppr (so 1440 counts per rev)) to replace the existing "manual" encoder wheel I...
51
2,716
