OT Google Trick
rdrast
Apr 2003
South Carolina Lowcountry
5,544
As I saw it come up in a resurrected thread, I thought I'd mention here how to use Google search to search the boards here (and, on any forum).
Most of you probably know about this tool, but for those that don't, it can be helpful.
Here is an example to copy into the Google search box:
Code:
site:www.plctalk.net/qanda/ traffic light
Google looks at the first part as a command:
Code:
site:
Then it looks at the address following that, so it knows where to search.
Code:
Follow that with a space, and your search terms as with "traffic light" above.
I think you all might know this one:
siemens s7-1200 filetype:pdf
Tells Google to find only PDF files with the text.
Excellent Tip! This will be very useful for Web Sites that have dismal Search Engines. Including AB/Rockwell.
Stu....
It can also be the other way around. Also the advanced options further narrow down the search. The wording of your search helps expand or narrow it also.
Didn't know that, thanks. And I like the way the forum turned ":p" into a smiley face! But I get it "filetype:pDF"
P.S. I clicked "Disable smilies in text" so it wouldn't happen again.
is it just me, or has something happened with the google search when using chrome? looks likes safari on mac is ok, but edge/chrome on windoze has...
838
Hi, We have our files on google drive. But it happens alot that the TIA portal project can't sync. It get red X on the .ap16 file and is never...
500
Google Grow is now offering 5 professional certifications. If you are like me you like the non traditional methods of learning (unique and online...
1,881
Back in the old days of ProfiBUS, I used to use this little adapter card that plugged into my laptop, it was like a compact flash card but taller...
1,608
Hello all Did anyone send an alert from M241 via google smtp. Currently, Google rejects my mail. Any information is welcome. Thanks
2,963
