Panelview 550 connection
GrahamV
Jan 2006
Indiana
I am trying to communicate between a Panelview 550 and an SLC 5/03 processor with a 2711-NC13 Cable.
The original Panleview failed (2711-K5A2) and we replaced it with a 2711-K5A5 (that we had available here), FRN 1.07 and the processor is an SLC5/03 - OS302.
I have changed Channel 0 - System to DH485 using RS Logix in the PLC program and changed to the correct catalog and revision number for the Panelview with Panelbuilder, however I cannot communicate between them.
The RS232 light is illuminated on the PLC, the PLC node is 5 and the panelview node is 6.
Any help on the above would be much appreciated? Please let me know if I have missed any information that would help?
The baud rate is at 19200 on the panelview and in the communication set up on the PLC it is the same.
I think so, in panelbuilder comms set up, the node address for the PLC is 5 and the terminal node address is 6.
Max node addresses? Did you change it on both sides or leave the default. (is 31). Just throwing out ideas.
The max node address on both sides is set at 31, thanks for all the help so far, I am going to try a couple of other ideas, I will let you know how they work out.
Hi all, Im having trouble transferring a program from one panelview 550 to an new one. I can insert a flash card into the old panelview and upload...
20
367
Client has multiple spare Panelview 550 (2711-T5A10 L1 PV550 Touch Devicenet)...
704
need instruction on how to download an existing program to the PV. I am very new to PLC's they came with the job so now sink or swim don't want to...
928
Good afternoon I have a panelview 2711-k5a2 ser B Rev-C frn 1.07. Can this be up graded to Rev J frn 4.10-4.XX? Thanks
17
3,458
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,264
