panelview 550 connections
cjkane2005
Jan 2010
Iowa
I have a panelview 550 CAT. 2711-B5A2 I am trying to get online with. I am using a laptop with no serial port. I have rslinx lite. Also I want to link this to an SLC 5/03 and then after all of this is done I want to get the panelview and the SLC on ethernet. Anybody know how to go about doing any of this? I am new to the older AB stuff.
Your PanelView supports DH485 protocol. Without a real serial port on your PC you will need a 1747-UIC ( USB to DH485 converter) or a memory card to upload/download a program to the PanelView. ( see PDF below for info on the 1747-UIC).
Another solution is to use the passthru configuration with the SLC5/03's serial port DF1 to DH845 passthru. ( see pdf below for more info on this.
Connecting your SLC5/03 to a PV that supports DH485 by way of ethernet you will need some extra hardware. See one possible solution at link below $$$. Your best bet here is to get a PV that supports ethernet and a 1761-net-ENI module ( Ethernet Interface) for the SLC5/03's serial port.
http://literature.rockwellautomation.com/idc/groups/literature/documents/in/1747-in063_-en-p.pdf
http://www.factorycomm.com/dl4500ed...485+ethernet&gclid=CMKQ0bzOnJ8CFQoiagodLEbnWQ
I ordered a SLC 5/05 and a ethernet capable panelview. Seemed to make a lot more sense. Also using the stepforward program from AB so the cost wasn't much more than having to install and stock all of the converters. Thanks for the help
Hello All, I was wondering what cables and potential connection senarios that are possible with a PanelView 550. I enjoy working with PLC as a...
17,216
Hi all, Im having trouble transferring a program from one panelview 550 to an new one. I can insert a flash card into the old panelview and upload...
20
370
Client has multiple spare Panelview 550 (2711-T5A10 L1 PV550 Touch Devicenet)...
706
need instruction on how to download an existing program to the PV. I am very new to PLC's they came with the job so now sink or swim don't want to...
930
Good afternoon I have a panelview 2711-k5a2 ser B Rev-C frn 1.07. Can this be up graded to Rev J frn 4.10-4.XX? Thanks
17
3,463
