JohnRatHolten
Hey all,
Hoping someone can point me in the right direction here....
I have an older AB Panelview Plus 600, 2711P-T6C20A, that I'm trying to reset to factory defaults.
By older, I mean that it doesn't match up to the description in the manual (RA Pub 2711P-um006),
The manual shows a procedure where (with a USB keyboard connected) you hold the Default switch
then press the Reset switch which takes you to the Maintenance Menu where you can navigate via the keyboard
to Restore Factory Defaults. And I have done this before on other PV's.
But, this PV does not have a Default switch that I can see (unless it's hidden under the back cover somewhere?).
Anyone out there have any info on this?
Regards
JohnR
Regards
JohnR
