Panelview Standard coms withControl logix
Frinehart
Jul 2018
Ohio
21
Hello all,
I know I have asked questions on this before, but does anyone have insight as to why discrete I/O would work on some screens but not on others post conversion from PLC-5 to Control Logix? My panel I/O is set up through a buffer routine, but when I go to impute numeric values into registers I get a Mistake Pop up saying "PLC did not acknowledge Enter Bit.", as well if I go to the integer register for the same numeric value in the PLC and change in there it does register on the screen. Could I have missed a I/O mask on this?
Best regards,
Frederick
Do the Control logix tags have read/write access or just read? In 5000 choose one of the tags and go to edit, down at the bottom, you will see type, scoep, and access, make sure read/write is selected. This has bitten me once upon a time.
I do have the integer array set to read/write, thank you though I would not have thought of that being the issue.
Had an interesting experience this morning. An old Panelview 600, 2711-K6C5X series B to be precise, comes up as error 32. Unfortunately it...
209
Good evening. I am in serious need of help. I am trying to connect a Panelview Plus 7 Standard to a SLC5/03(1741-L531) using a Moxa MGate...
639
Good evening. I am trying to get a SLC 5/03 connected to a Panelview Plus 7 Standard using a Moxa Mgate EIP3170 and I am not having much luck. I...
521
Hello, We have an older machine that has a standard PanelView (2711-T10C3) connected over DH485 to a SLC 5/04 PLC via a 1761-NET-AIC module in...
673
Hello All. I have an interesting one for you. I have a brand new Panelview 600 Standard 2711-K6C20 and I'd like to get it to talk to an L81E...
2,026
