Panelview to multiple slc5/03
Benyamin
Mar 2012
Dallas
67
Dear All,
I would like to know the setup and configuration of a Panelview to multiple slc5/03. Any input will be appreciated.
Regards,
Benyamin
The exact wiring will depend on the exact model of PanelView terminal.
The native network of the SLC-5/03 controller is Data Highway 485. It's typically built as a "daisy chain" with isolator modules at each node.
Those isolators can be 1747-AIC or 1761-NET-AIC. With very few exceptions, those isolators need to be part of the network.
The best installation descriptions for DH485 wiring will be found in the installation instructions for the 1747-AIC and 1761-NET-AIC.
Thanks for the respons, I will try to search deeper, by the way, how about addressing for each SLC, if I have two SLC5/03?
Please help.
Regards
Benyamin
In the project under 'Channel Configuration' - 'Chan 1 -System' tab you can set the node address. if you change it from '1' online or after changing it from '1' offline then downloading you probably will have to go offline then change the node number your DH485 driver is looking for. (I haven't done this for DH485 but having to change after downloading is true for other drivers after changing the address.)
I've had success using the 1761-NET-AIC and daisy chaining via DH485. Just be sure to change your node addresses as mentioned above.
Hi Guy's, I have a project to link multiple HMI's to multiple PLC's that will all run the same process. I want to be able to call the mimic from...
1,582
Can anyone tell me if it is possible to use Factory Talkview ME programming software with a new Panelview Plus HMI to read tags from multiple SLC...
1,640
I have what I hope is a simple question. Can I run two PanelView Plus touchscreens with identical applications talking to the same compactlogix...
19
7,995
Hello everyone, I have to program a PanelView plus connected to a Compact Guardlogix controller. The client has specified that there should be an...
3,161
I've never tried to do this before, and I've thought of a few possible solutions, but they all feel like kludges. I have a control system...
6,881
