Panelview Upload
nmark
Apr 2010
US
Hello,
I am trying to upload a application from a Panelview 1000(#2711-K10G8).
I have a RS232 cable#1747-CP3,SER.A. plugged into my laptop and the other end plugged into the terminal rs232 port .
I have tried uploading directly from Panelbuilder 32(results in Error2018), WinPFT(results inError 2018) and Rslinx with no success.
I can use the 1747-cp3 cable to upload and download to the slc5/04.
So I know my cable is OK.
Does anyone have a suggestion?
For future reference, please note that even if your Panelview WAS an RS232 version, the CP3 cable will not work. You need something like an AB 2706-NC13 or 2711-NC13 cable.
Thanks for the replies.
Is it possible to use my 1747 -CP3 cable thru the slc5/04 and upload
the panelview application.
My intent is to upload application change password and download.
Yes, see PDF's below for passthru info.
But with a null-modem adapter on the end of your 1747-CP3 cable
making it a straight thru cable will work also. Or go to Radio Shack/Best Buy and get a straight thru cable. Or a memory card for your PV program.
Hello, I have a machine with a 1756-L72 Controllogix PLC and 1756-EN2T network card, and PanelView Plus 7 HMI. I am using RSLogix V20.05.00...
924
Hi all, I have a 2711R-T7T running an application without a shutdown button in the current program. I've looked at all the manuals and can not...
1,268
I have a machine that was powered off for repairs, when powered back on the Panelview fails to upload the tag database from the PLC. Its a...
1,547
Hi All, I have an issue trying to upload a program from an existing Panelview 1000 terminal that I was hoping I might be able to get some help...
2,228
Hello, anyone had a similar experience? A customer has an old panelview600, it is faulted, but is communicating and they desperately need to...
3,766
