Picosoft Help
brendel20
Sep 2015
IL
I'm new to picosoft. I've been working with it for a short time now and have been able to write a simple program that will turn 4 outputs on sequentially. My questions is....how do I thing turn them off 1 at a time?? I'm using 4 timers to turn each on at 2 second intervals but when I attempt to assign 4 more timers to those same outputs, everything goes haywire ;)
Here is an example of using two timers to one output. You will need to expand it for all four outputs by adding rungs and increment the addresses. It will not work for you as is. It is just an example anyway. There needs a little more programming to actually get it to work which would include some intermediate rungs to set the timer values.
Ok...getting close. I'm attached a pdf of what I have. How does timer 2 turn off Q1? Thanks for your help!
As I said in my post that was only an example on how to combine some things, not how it should work to solve your request. At the risk of doing your homework and getting criticized for doing so, here is another example that works but keep in mind that it may not yet do exactly what you are asking because you haven't clearly defined the entire process step by step.
Hello all, I am working on a simple program for an AB Pico PLC. Some info first: In the image below I01 is a ready signal from a machine. This...
5,929
Hello, Im new to plc's and im trying to use picosoft to build a simple timer circuit that is controlled by input 01 , and as long as 01 is on the...
2,040
I have a series of solenoids I need to run on set time amounts as long as an input is closed. The problem I cant seem to nail down, is I only want...
1,279
Does anyone know how to download Picosoft software, I tried the AB site for the free download a dozen times and it gives me an error after I allow...
2,315
I have a Picosoft controler that I am trying to use the counters in the ladder, but no matter what I do, the counter output shows on, even before...
2,056
