PLC5/40C Remote I/O -> PowerFlex Drive
cntrlfrk
Feb 2006
Nebraska
244
I haven't done much with remote I/O, so I thought this would be the place to go once again.
I'm adding a PowerFlex drive as remote I/O connected to the PLC5/40C channel 1B. Currently, we have 4 drives on the 'remote I/O highway' all configured as 1/2 Racks with addresses of (R16,G0) (R16,G4) (R17,G0) (R17,G4). These are the only items configured on the RIO Scanner.
From what I understand, valid rack addresses for a PLC5/40 are 1-17. Is there any reason I can't add a rack at 15? Why would anyone start with Rack 16 in the RIO config? Once the address is set in the scanner, and communications is confirmed with the drive, do I need to do a BTW and BTR or can I directly access the drive start/aux/ speed commands directly as O:151/1--I:151/1--O:152?
Thanks.
I was wondering if it was possible to set up Ch.3 on a PLC5/40C for Ethernet? I have disabled Boot P and given the Channnel an Ip address with the...
1,345
Hi, I got big trouble for install VFD in existing PLC5/40C. Existing PLC5/40C DH+ Channel A connect to daisy chain 4 PLC and PC workstation...
1,931
we're currently replacing starter mars with VFD powerflex700 with 20 COMM C communication adapter. we're use PLC5/40C. i read in this forum...
4,715
As the title indicates I am trying to connect a PLC5/40C to Honeywell Experion R301 using 1785-ENET card. I am not really familiar with PLCs at...
2,997
I have a PLC5/40C with a 1771-NOC-A Analog Output Card connected to a 1771-RTP4 Terminal base. The problem is, we are having a problem changing...
4,213
