PLC5/40C W/ 1771 NOC-A Analog Output Problem
cntrlfrk
Feb 2006
Nebraska
244
I have a PLC5/40C with a 1771-NOC-A Analog Output Card connected to a 1771-RTP4 Terminal base. The problem is, we are having a problem changing the 4-20mA Output. No matter what we do, we are only seeing 3.95mA. I'm guessing this is a setup problem but everything seems OK.
Any ideas?
Also, the Run/ Fault light is flashing green, on 1 sec/ off 1 sec. Cal/com light is mostly steady on (grn) with a flicker I assume is communications data movement.
In my PLC5/40 Manual it says a blinking green processor light indicates that the processor memory is being transferred to eeprom. I can't verify if this is correct for a 5/40C though.
If you go online with the controller, what is the status of the CPU?
I was wondering if it was possible to set up Ch.3 on a PLC5/40C for Ethernet? I have disabled Boot P and given the Channnel an Ip address with the...
1,345
Hi, I got big trouble for install VFD in existing PLC5/40C. Existing PLC5/40C DH+ Channel A connect to daisy chain 4 PLC and PC workstation...
1,934
we're currently replacing starter mars with VFD powerflex700 with 20 COMM C communication adapter. we're use PLC5/40C. i read in this forum...
4,715
As the title indicates I am trying to connect a PLC5/40C to Honeywell Experion R301 using 1785-ENET card. I am not really familiar with PLCs at...
2,998
I haven't done much with remote I/O, so I thought this would be the place to go once again. I'm adding a PowerFlex drive as remote I/O connected...
5,115
