PLCSIM & TON timer problem
Krcedinac
Jul 2006
Krca
163
Hello to all,
This morning I wanted to test some simple CFC programing with PLCSIM. I was supprised when I saw that it is not working OK. Then I realised that SFB4 - TON timer is not functioning properly. I have to put 5 days delay time in order to have 10 seconds delay in pasing the signal. If I put something like 2 minutes it gives signal right away. What is interesting SFB5 - TOFF timer works OK. I tried code with real PLC and normaly everything works fine.
I remember that PLCSIM worked fine with this timer in the past. What could be wrong now??? It is PLCSIM v5.3+SP1
I dont know why Siemens hasn't put the Hotfix that adresses this problem on their support site. If you PM me your email adress, I can send it to you.
..Oh never mind, I see that someone has put a link already.
Hi guys ! I'm setting up a simulation environnent with Siemens for PLC and Eaton for HMI. To achieve this, i'm using : - PLC simulation ...
1,578
Hi I used to be able to launch PLCsim without any problem. Now it tells me " STEP 7 Professional Licence is required to simulate this PLC"...
539
Daft question coming up...When I want to modify a value, what's the best/correct way to do this? At the moment, I am entering the value (e.g...
442
Hi, I want to use PLCSIM because the hardware I was working on has now been delivered to customer. Which option do I choose from this drop-down...
373
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
576
