[SIM] PlcSim and Galileo (eaton/moeller)
Librentez
Jul 2015
Singapore
Hi guys !
I'm setting up a simulation environnent with Siemens for PLC and Eaton for HMI.
To achieve this, i'm using :
- PLC simulation : Siemens S7 PlcSim
- HMI simulation : Galileo 8.03
- Gateway/link : Nettoplcsim
Everything is almost working but :
Read a byte from siemens DB : OK
Read a bit from siemens DB : Error.
The error appears when I compile the HMI :
"ERROR: bit 'MyBit':the size of 1 bits is not supported (increase to 8 bits) -- PLC 'Siemens - Industrial Ethernet'
If I declare a new byte in the HMI and map it to the BIT DB adress, this is working... but not clean. And i means that i'll have to change everything later ?!
Thank you for your feedbacks !
Ronan
Hi I used to be able to launch PLCsim without any problem. Now it tells me " STEP 7 Professional Licence is required to simulate this PLC"...
539
Daft question coming up...When I want to modify a value, what's the best/correct way to do this? At the moment, I am entering the value (e.g...
442
Hi, I want to use PLCSIM because the hardware I was working on has now been delivered to customer. Which option do I choose from this drop-down...
373
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
576
Hi, My PLC hardware has been delivered to customer site - many thanks for the invaluable help on this forum! I was looking into see if it's...
2,528
