Position Deviation Xerr in Telegram 105
Kataeb
Jan 2007
www.livelovelebanon.com
636
In Profinet (or Profibus) communication between S7-1500T (or Simotion) controller and S120 () drives, and when working with DSC (Dynamic Servo Control) , they send the Position Deviation Xerr (in Telegram 105) from the plc to the drive . Then they add to it the Position Actual Xact inside the drive to have the Psetpoint again !
Why not they simply send the Position Setpoint from the controller to the drive ?
Can someone please explain this concept ?
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
153
Hi All, I could do with some advice on a hydraulic control system. It is necessary for me to accurately position a vertical hydraulic ram with...
34
1,912
Hello I am trying to make a program work with a sqo instruction .The process has 5 steps ,and a starting step of zero.There should be 8 sec...
17
1,053
It's been a long time since I've had to think of P&ID tag nomenclature myself (and not gone along with some scheme devised by someone else). I've...
240
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,144
