Power Supplies: Linear vs. Switching
Dongleboy
May 2003
VA
Fellow associates,
I would like to solicit some feedback regarding your preference of external power supplies used in control systems. Specifically, linear vs. switching.
I am well aware of the differences between the two in regards to efficiency, noise, etc, but I would like the opinion of the experienced.
Kindest regards,
Dave
I generally use a switcher in new installations.
Smaller, cooler, and more efficient. Hard to lose.
I find that any industrial duty electronics - prox, PLCs, solenoids, etc. have no problem with the switcher.
Same here. I have been using the ones that run off of 480VAC three phase. If it weren't for the laptop plug-in outlet requirement, some of our machines wouldn't have a control transformer.
Why bother with expensive regulated power supplies for operating solenoids and contactors?
A single-phase bridge & capacitor should be adequate.
A 3-phase full-wave bridge with no filtering would do nicely.
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
110
is this possible? i have a customer has has a large factory, he has 2 x 800amp supplies coming into the site and would like to switch between...
921
Hey Guys, Can anyone recommend a P/N for 48VDC input, 12VDC output power supply. I tried looking up Phoenix Contact/ RHINO, and wasn't able to...
1,485
Is there any problem with connecting two or more 24V DC power supplies in parallel to get more Amps? I have one 40A supply on a large machine...
21
7,393
Hi all, I was hoping someone could tell me if there's an advantage between using PULS or AB power supplies that are rated for SELV and PELV? I...
1,990
