Powerflex 753 - Unable To Change Parameters From HIM
The DPI logic is telling you what is controlling the drive....but it doesn't affect the Accel/Decel rates. That bit tells you what's selecting Accel 1 or Accel 2, not setting the value of the Accel. You need to follow the above people's advice and look at your DataLinks and internal links. Almost assuredly, either an internal parameter or the DataLink from the comm module is pointed at your Accel/Decel parameter. This method was common to Datalink them to the PLC so a technician could change rates from the PLC/HMI and not have to access the drive. if it's datalinked and the drive is not connected, it will still default to the last known value or default. I don't think it will let you change it because it is link sourced from somewhere else.
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
109
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,364
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
457
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
563
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
723
